Anonadado me quedo al pegar un vistazo y ver que el post ha superado las 100.000 visitas.
Ya que estoy por aqui, añado alguna cosilla:
PART NO. 2307
Sachs Shock Bladder Kit
Eliminates friction and greatly reduces heat over the conventional piston design
Offers a more reactive, smoother ride and absorbs small bumps better.
FITMENT: Husqvarnas and GasGas with Sachs shocks
PRICE: $57.00
PART NO. 5001
GASGAS 124mm Linkage Pull Rods
Offers much improved straight line stability over the 122mm stock units
Complete with bushings, ready to bolt on
FITMENT: All GasGas 2-strokes
PRICE: $74.00
PART NO. 5003
GASGAS Ultra cooling Impeller
Precision machined for reduced hydrodynamic drag
Coolant flows at a higher velocity to prevent power loss from overheating engine and clutch wear from overheating
Replaces the OEM plastic impeller that distort under extreme temperature and diminish cooling capacity
PRICE: $49.00
¡Ojo!, esta es muy interesante:
PART NO. 5005
GASGAS Teflon Coated Wheel Spacers
Replaces the fast wearing OEM spacers
Rears are hard coated, Teflon coated precision machined aluminum
Fronts are 303 stainless with anodizing
FITMENT: All GasGas
PRICE: $26.00
PART NO. 5007
GASGAS Rear Brake Pedal bushing
Replaces low quality stock piece
Machined from 303 stainless for no wear
FITMENT: All GasGas
PRICE: $23.00
PART NO. 5011
GasGas Power Valve Cover
Larger volume chamber makes more low to mid range power and better throttle response.
Machined from solid billet aluminum to exacting tolerances.
Drain screw allows for elimination of excess oil.
FITMENT: All GasGas 2-strokes.
PRICE: $84.00
Todo esto y más en:
http://checkpointoff-road.com/store.html
Y otra más,para los que se quejan del consumo:
http://www.rvaqualine.com.au/
